kp
Dont drive my Model A much at night, headlight reflectors were in bad shape,tried using allum. foil ,didnt help much,so ordered new reflectors (foreign made) they are smaller in depth, ie bulb socket with spring and screw that allows bulb to be retracted or extended isnt long enough to allow this function,guess the fix will be to purchase a longer spring and screw any body else had this problem ? How did you fix it?
the reflectors are ok otherwise,havent tried 'em out at night yet.I do have higher wattage bulbs.Staying as original as I can afford to.
