Head gasket
Hank/Mi
I can't seem to find a copper head gasket for a B engine with a 6:1 Snyder head. They say you have to use a B head gasket and I'm not fond of the silicone gasket. What would you guys recommend using?
TIA
Hank/MI
Hank;
Contact Bob Johnson who has been posting here on the Barn. He started his saga maybe with a blown head gasket. He has done quite a bit of research into "B" gaskets and found that the area around the "steam holes" was too narrow to contain the water passing thru. A check has found that the all of the gaskets he has are too narrow and that years ago this area was .150 or more wider. I have plugged my "steam holes and will be running a 7 to 1 Thomas A head, so I don't have to worry about what Bob has discovered. By the way my old time 4 cylinder & flathead V-8 machinist and engine builder says to to use the new silicone impregnated type gasket with my combination!
Steve
The 4 steam holes are only on B blocks, and must be plugged flush with the deck in order to support the A gasket used by most aftermarket heads.
Slightly off topic, but I will be installing a 5.5 snyder on my new engine and I would like to install a 'modern' silicone head gasket on her. Is this the right head gasket to use? I like them better than the copper ones.
Mike
Several years ago I installed one of the "modern" head gaskets on a Snyder 5.5 head. Shortly after I went on a 1200 mile tour. When I got back and went to change the oil I noticed about an inch of the head gasket had delaminated and migrated and was sticking out under the water pump. The gasket had not blown, it was still holding compression. I removed the head and replaced the gasket with a copper FelPro. The removed gasket showed carbon streaks where it had delaminated. It was about to blow.
I am told that others have experienced this same failure mode early on and that the "modern" gasket has been improved. I still won't trust them. I use the FelPro on both my cars, one has a Snyder head, the other is a Brumfield.
Tom Endy
Tom Endy
I like FelPro also, but they don't make copper one for a B head. I prefer copper, but I may have to go with the silicone. Snyders said you have to use a B style gasket with their 6:1 head. I think it is because the area in the head is cut back for the bigger valves.
I'm using a Best brand composite "A" gasket I got from Max at H&H Engine. It has plenty of room for bigger valves--I have 1-7/8" OD valves in my engine. I would think the Best copper gasket MikeK mentioned above would have the same contours in the "B" version or the "A" version.
Joe
Mike: I have three cars running with Snyder's heads and all of the cars have the newer "silicone" gasket. The gaskets are holding up well after considerable mileage on all three. I have found that the gaskets do compress and required a number of re-torques before they stabilized. A number of fellows in our local club have experienced silicone gasket failure but, in all cases, the gasket was torqued once and not checked later. Gar Williams
