I am having trouble getting a head gasket to seal around #7 cyl of my 57 312. I have tried 2 times to get one to seal and both are leaking around the 7 cyl. Before I tried it this last time I took the block and the head to the machine shop. They decked the block but the head was okay. We thought that the head getting decked would fix the problem but it did not. By the way, both sides of the block were decked and the right side (1234) sealed just fine. When I installed it this last time I made sure that the gasket(felpro) was positioned correctly. I torqued the bolts in 3 steps, 55,65,75 final. And I used the order of fastening shown in the manual. When the gasket did not seal I even removed the rocker arms, exhaust manifold and torqued While hot to 75lbs agian. Still no luck. Does anyone have any suggestion before I pull out what hair I have left!!!!!!!!!!!!!!
