Growley bear
I am not trying to hijack any posts or bash any parts vendors here.
This is an on going problem at my club in Coos county, OR. Two members same problem. 6:1 Snyder cylinder head premium head gasket and the fiber gasket also from Snyder's pictured here. One owner had this happen twice; he owns a machine shop and is a first class machinist. He switched to a Lion lll speed head and has had no more problems. The other engine, same thing only three gaskets blown at less than 500 miles each. At this time a 5:1 Snyder head has been substituted for the 6:1.
I also need to mention that both engines have been using 9lb pressurized cooling systems.
No one seems to understand what is causing this. To my knowledge not even Tom or his engineers. Has anyone experienced this and if so did was it repaired?
This erosion has taken place from the inside out toward the combustion chambers on cyls 2&3 every time and has been the same with all gaskets used. Any help or suggestions are of great importance and would be much appreciated.
The head gasket here is P/N B-6051-C. I don't have photos of the other gaskets. I wish I did.
Chet
Chet
