I am building a block that's been decked a lot, I have copied the curvature of the top of the piston... I machined the same curve onto a used piston, cut out 1/4 off the top to be able to see the curve in the heads, and by using spray graphite and a different block-to stay located- using a bur and porting stuff, doing my own doming job... As I go, I check piston to head interferance with feeler blades between head and block, shooting for .020- to give about .040 clearance with gasket... Karl
In your case, I'd find it simpler to re-machine the dome on the pistons you are going to use. Most flathead pistons can tolerate some cutting. Unless of course, your going for pop-ups. Need access to a lathe of course.
