I have a friend who is about to install a high compression head (I don’t know the manufacture). He doesn’t want to use standard grade 8 studs and instead plans on using grade 8 bolts and washers. He reasons that the car is a daily driver so why not use bolts instead of studs. Plus he believes it would make it easier to get the head off in the future not having to remove the water pump by simply unbolting the head. It’s not the route I’d take but what is the argument in bolting VS using studs to attach the head? Thanks
