Habusailor
On a 1935 with cast iron heads should there be washers under the nuts?
Gary, Do you offer these in stainless & will they work with acorn covers? Thank you. BillIf you decide on using washers (very good idea on either iron or aluminum heads) we have available "special" ones that are barely visible under the nuts or bolt heads!
Thanks, Gary in N.Y.
P.S. Here's a shot of them with some OEM bolts, you can see they would almost be "invisible", but they do work!
Gary, Thank you. The black will be fine when I get to that point. I was concerned with the covers not hiding the washers.Hi Bill, those "black" washers in the photo fit under the chrome acorn nut covers we have on the shelf here.
The O.D. on the washers is .675". May be difficult to see clearly but the photo below shows the entire washer sitting inside the chrome nut!
P.S. Not sure if ARP has them in stainless in the same size, I doubt it though? Will give them a call later in the day, they're out on the west coast, and report back!
You can get ss AN flat washers in .745 OD for .06 each.
The OP wanted to know if washers were used on 1935 cast iron heads.
