rambunctious
New member
having troble with clutch linkage/force for 8BA/39 ****** combo
dad's friend built a period correct model A hot rod for us with 49 Ford 8Ba and 39 ******.
the clutch efforts are very high and because of an offset from the pedal to the clutch lever arm, I have continued to bend/buckle the fabricated offset linkage.
I made a stronger one, but am afraid to lengthen it to set the correct length as I feel the clutch lever arm efforts are just tooo high?, wondering if something might be wrong in the bell housing.
He originally had a merc engine in the car, then put the ford engine in. so maybe he has the proper merc components,
I plan to check with him,
but... my question. what is the efforts to release the fork. what torque on the clutch linkage, or what force on the linkage lever arm is spec or typical.
I cannot release it by hand with a medium length wrench.
thanks
Ramb
thanks
Ramb
