Same here.I have a harmonic balancer on my flywheel from Ron Kelley...
I have a harmonic balancer on my flywheel from Ron Kelley. It's also counter balanced. No vibrations from the engine.
This gentleman's, (Mr. Ron Kelley's), vast & rare Model A/B engine performance advice is always based on pure facts derived from his past experience & detailed testing with "calibrated" dynamometers & "calibrated" testing equipment.
He does excellent work.
Forgive me, but how does this relate to the question the original poster asked.![]()
... harmonic balancer...
... harmonic balancer ...
I could ask the same to you. But I just simply wanted to share my experience with the harmonic balancer in the flywheel.
True dat!. . . He wants one that works, ...yours does not!
I have made one, a fluid damper, out of one for a sbc. It used a modified Model B front motor mount, and a pulley that used a 1/2 wide belt. We did not have to cut the front crossmember. This went into a speedster with an alternator and an electric water pump. The trick is to find one small enough to start with, as the diameter and the width are kinda tight.
Why can't we agree to disagree without getting pissy... He wants one that works, ...yours does not!
