ArtimusGordon
Engine turns over normally but when I PULL the choke out,momentarily, the engine STALLS but SLOWLY continues to turn then FIRES and runs. I have a 6volt battery and did a load test on it and it tested fine. I also did a vacuum test and all indicates normal. I have the same starting problem when the engine is warm on a restart. Could this be a starter problem? Can I test the starter with out removing it from the engine?
