rbassemir
I have what I believe is a 1938 flathead in a 1935 Ford Convertible Sedan. It used to start pretty reliably even if it sat for a couple of months but that has changed and I'm looking for suggestions for things to check. Here are the symptoms:
It started up on Mother's Day and we took a ride down the street. After going less than a mile, it stopped and would not start again. I was low on gas, so I added some more to be sure I was not out of gas. It would crank but would not start. I checked for a spark with one of those in line spark plug testers and saw a spark. I pulled a plug and it appeared to by dry. I sprayed some starting fluid and it did not even sputter. I towed it back to the shop.
In the shop I checked voltages and found I was getting 4.5 volts at the Battery side of the ignition coil. I disconnected the fuel line and cranked the engine to be sure the fuel pump was working. It was. I could not see any gas in the carb when I pumped the pedal. I suspected it was a carb issue.
I pulled the carb and there was a fair amount of dirt in the bowl. Went through the entire disassembly and reassembly of the carb cleaning a blowing out all orifices. Put it back on and the car started. I thought I solved the problem.
The next day I could not get it started again. Same symptoms but this time I can see gas being squirted in the carb when the pedal is pumped. After multiple attempts I had to put the battery back on the charger. Later that day is started on the first attempt. It seems to have a mind of its own. I periodically try to start it. Sometimes it starts and sometimes it just cranks. I have not yet found any pattern to the problem.
I have 6.2 volts at my battery, but under the dash it is down to 6.0 volts and on the output side of the ignition switch it drops to 5.8 volts. Through the ignition resistor and I end up with 4.5 volts at the coil. I don't like that but maybe that is not a problem.
I have not pulled the distributor cap or checked the points. Since starting fluid does not seem to get the engine to even pop, I am thinking I have a weak spark? My ignition line does go through a resistor which accounts for less than 6 volts at the coil. Could the capacitor be the issue?
This is my first flathead and have ever tried to do any ignition timing. I have not changed the plugs or wires since I purchased the car. It used to be fairly reliable, but lately I have lost confidence in its reliability.
I would prefer to stay with a 6 volt setup but if going to a 12 volt setup is going to make the car more reliable, I would do it.
Your comments / suggestions are welcome.
