Hard to find
wkvasnicka
Looking for a Script coil and jack handle for my 1931 68C.
Vendors either no longer carry or do not stock the coil and all are out of stock on the handle.
Thank you for any assistance you may have in locating a source either one.
Good Morning...You might give a call to Arizona Model A. Sammy Guthrie might well have one...480-782-0266. Ernie in Arizona
Mac's had them, but now says discontinued.
If you still have your script coil, it is just a canister with a modern coil in it. Twist the coil end with one hand and the other hand gripping the canister, twist in opposite directions. Once it breaks loose, keep twisting and pull the two pieces apart. Get a new coil and push it into the canister. Make sure when you put it in, the plus side pole goes on the drivers side for the red wire.
