Hard steering
Russell Reay
My 1930 huckster steers very hard, but I have still put on 1000 miles this year. I just drove a friend's cabriolet with good steering, and what a difference ! It has been suggested that the tie rod/ drag link ends may be too tight, and having installed the EZ steer nylon parts I think it is very likely. I screwed in the plug just enough to insert the cotter pin, but the spring pressure at that point was tremendous. I plan to re-install the original steel parts (the balls are are rebuilt) to see how it feels. The washer/ shim shown in the photo was in one of the four joints--I don't remember which. There is no mention of this part in the book, but it shows significant wear. What should I know about this part?
That thin cup-shaped piece goes in the drag link at the pitman arm end. The pitman arm ball presses against it. This is the only spot on the 4 tie rod and drag link balls that uses this piece.
If you have hard steering, I predict the problem is in the thrust bearings on the top of your kingpins (one on each side). The bearings may need fresh grease, or they may need to be shimmed up a bit.
With the weight of the car on the front wheels, see if you can turn the outer housing of the thrust bearings with your fingers. If that bearing is properly supporting the weight of the car, you should not be able to turn it. So if you can turn the bearing, it needs a shim under it.
If you take it apart to add a shim, use that as an opportunity to clean any old, dry grease out of the bearing and pack with fresh grease before you reassemble.
It will help if you take the time to polish the steering arm balls to a "ball-bearing" surface. Use the original steel cups/washers/springs. Jim is correct in looking at the kingpins!
Analyze one thing at a time. King pins, tie rod, drag link, steering box, low tire pressure. If the EZ steering parts are too tight then it is possible it was put together wrong.
These slides may hep you.
Holy mackerel !! Bob's sketches suggest the source of my problem. All four of my joints are assembled with the end plug screwed against the spring, none like his first photo with spring inside. I'll keep you posted.
Look carefully, one end of the drag link DOES have the screw plug going in against the spring. For most cars that is the end at the pitman arm.
The other 3 have the screw plug going in against the ball.
Disconnect the pitman arm from the drag link and turn the steering wheel. If you can easily turn it with one finger lock-to-lock, the steering box adjustment is not the problem. Now go to one extreme and give the steering wheel a firm spin. It should go all the way to the other extreme in three revolutions without stopping on its own. If it won't do this and wants to bind in the middle of its travel, the adjustment is too tight, especially the third one. Go back through all three in-car adjustments until the steering wheel passes these tests.
As Jim/GA recommends, test the king pin bearing tightness. You should not be able to turn the bearings with your fingers with the tires on the ground, but you should be able to do so with the front end jacked up. If they pass this test, you can scratch poorly-shimmed king pin bushings off your list.
While you have the front end up on jackstands, wiggle both front tires inward and outward at the top and bottom. There should be very little if any movement laterally. No movement is ideal, of course. This test will tell you whether the king pins and their bushings are in good shape.
With the drag link still disconnected from the pitman arm and the wheels off the ground, push and pull the front wheels from side to side as if you were going around a corner. There will be more resistance in doing this than when spinning the steering wheel with the drag link disconnected because of the weight you are moving: backing plates, heavy brake drums, brake shoes, spindles, tie rod, etc. But you should be able to go back and forth with only minor resistance. If this test passes muster, the tie rod end plugs are not too tight. If it is difficult to move the tires back and forth, back out the tie rod end plugs 1/2 turn at a time until the wheels can be moved back and forth with relative ease.
That only leaves the drag link end plug adjustment. Reattach the drag link to the pitman arm and adjust the end plug per recommendations given here so far. Test resistance via the steering wheel. If it's difficult to turn the steering wheel, back the drag link end plugs out another half turn and try again.
Once you have done all the above, sit on the ground straddling the driver's side front tire. While you move the tire back and forth, front to rear, watch the drag link connection at the pitman arm. If you see the arm moving before the drag link does, tighten that end plug 1/2 turn and test again. You want to reach a point where the pitman arm and drag link move at the same time without binding or undue stiffness. Check the front of the drag link the same way. The steering arm should move at the same time as the drag link does.
If your steering box and front end pass all these tests and the car still steers hard, check the front axle's caster, meaning the angle at which it leans backwards at the top. I believe that angle is supposed to be 5 to 7 degrees. If less than that, the steering will be hard. Stand a short L-square against the bottom of the front axle's raised lip and ensure that the flat side of the L-square is perfectly level on the ground. Measure the distance between the L-square and the TOP edge of the axle. It should be 1/2", which is close enough to that 5 to 7 degree caster figure. If the measurement is in the ballpark, the front end caster is o.k. and you can eliminate that from the list of suspects.
Also check the tire pressures. 34-36 psi gives the best all-around performance for ease of steering and tire wear.
Did you observe whether the sector shaft moves up and down inside the housing bushings? If it does, the bushings and/or shaft are worn and should be replaced. Looseness here will not cause hard steering, but slop at the steering wheel will be obvious. The usual cure by some guys (and usually the wrong cure) is to tighten the drag link and tire rod end plugs - which does not solve the problem and only makes steering more difficult. Rarely does over-tightening a Model A steering component compensate for wear in some other steering area.
'Just thought of another oddball cause of hard steering. Ensure that the bottom of the steering wheel hub is not rubbing against the top of the metal quadrant. This can happen only with two-tooth steering columns because the column jacket has not been pushed down far enough over the top bearing race in the gear box. If the steering wheel is rubbing here, it will cause hard steering with and without the pitman arm being connected to the drag link.
Ouch! I've got blisters on my fingertips from typing. Check out these suggestions while I let my bleeding fingertips rest up before typing the next SHORT response. :)
Marshall
Hello everyone,
I am also experiencing the issue of very stiff steering. The advice provided here is excellent!
However, I’m afraid I didn’t quite understand the part about checking the play in the kingpin bearing. Could you please clarify what exactly should be able to turn easily during this check?
Dankeschön!
Rotate this bearing between your fingers with the wheels off the ground. If it moves, that's what you want. You should not be able to rotate this bearing with the wheels on the ground. If you can, special shims need to be added beneath the king pin head.
Marshall
The bearing between the spindle and the axle,that the kingpin goes through,should NOT be able to turn by hand with the car resting on the ground.If it does turn,then it needs to be shimmed,because the weight of the car isn't riding on the bearing.Now,if you jack the car up,with the wheels hanging free,at that point the bearing should be able to turn with your fingers.It should not while sitting on the ground.
Update--The incorrect assembly I anticipated wasn't there, but a couple elements were out of place.-I removed the EZ steer nylon plugs and replaced them with the original steel components. Installed the washer in the drag link/pitman arm joint, greased everything, and the test drive revealed no improvement. A 5 degree turn on the sector mesh adjustment removed the play in the wheel. The king pins were/ are properly shimmed. We are headed to Tebo's Barn, and I am confident he will find the problem and fix it. Thanks for all the feedback
