flathead 53
I replaced steering box, tie rod ends ,center link ,king pins ,wheel bearings, Im running R215x78 front tires with 35lbs air pressure ,Only part not replaced is drag link.
Is the ride height correct , if high or low the drag ling will be pushing and pulling up or down hill rather than in a straight line .I replaced steering box, tie rod ends ,center link ,king pins ,wheel bearings, Im running R215x78 front tires with 35lbs air pressure ,Only part not replaced is drag link.
