Look for voltage drop in your starting circuit by connecting a voltmeter across a cable and try engaging the starter. If the meter moves up more than .05 volt, get the connections cleaned or a heavier cable. Connecting from the battery negative to the starter terminal and engaging the starter should not show more than 0.1 volt. You have disclosed that you do not have a cable from the firewall to a head bolt. You need that cable. You also need to check for voltage drop by connecting the voltmeter to the positive of the battery and to a head bolt and engage the starter. Again, the meter should read 0.1 volt or less. You have an Optima battery? Puts out very satisfactory starting capability.
