IvanT28
Hey ya'll, Had a hard brake pedal with no 1" free play. 28' special coupe. Had a brake job done a year ago. All new guts on the backing plate, (I mean everything) and new cast iron drums. Decided to do a better brake adjustment then what had been done. The brakes work great now. Just like the book. Full on - rears lock & fronts grab, no pull left or right. Had to change rod lengths to get it that way and the brakes seems a little softer. But I have no free play. !/4" at the most. I can drive it like this fine, but what would cause that? Linkage to tight?? Return springs are working, can't pull the pedal back any further. It has a N/S cross shaft, correct 15 degree tilt on actuator arm. I used a brake board for adjustment. Could barely get the pedal to move the 2" required. Is that normal? I read some where that ol' Henry had an inch of free play designed into that whole mess of marvelous mechanical lingage. I guess I lost mine some where. Any ideas are welcome.
