Handle?
Neil Wilson
Below is a picture of a "T" style handle with lock which was used on the model A panel delivery. I was told that there is a model T handle which is the same except for the shaft. Does anyone have information/pictures of this type of model T handle?
I had a panel delivery for many years. The handle was I believe unique to the Panel Delivery possibly the sedan delivery. I think one could be made from a rumble seat handle, you'll have to lengthen the square shaft, and an appropriate bezel from a door handle.
Jim Dix
Big Flats, NY
Hello Jim,
Thanks for you input. That might be the only route available. An A/AA'er in Arizona says that there is a model T handle which is the same as the one pictured except that the shaft would need to be modified. I am hoping that a model T expert will know which model T handle comes in the "T" style.
BTW - I have been working on the cargo floor for my '30 79-A panel delivery.
28 Model A decklid handle is the only T style I know of that is the same as the 1929 Model A Deluxe Delivery. I have thought about converting one of these. Rod
Here is one more pic I forgot I had. Just curiois in that the same escution as the 28-29 AA and pickup?? That may be the shared part with the Model T as it should be the same as the 26-27 coupe. Rod
Hello Rowdy,
Thank you for the pictures.
The November 15, 1929 body parts list shows that the rear door handle is part A-80994 for both the Panel Delivery and the De Luxe Delivery.
Your pictures of the handle with a key looks like the same handle as I have shown in my first note.
I have compared the escutcheon of the front door handles (closed cab) to the rear door and they are not interchangeable due to the opening size for the shaft cover. The closed cab handle does not have a lock in the handle and the shaft cover is smaller than the panel delivery.
I guess that my information source of a Model T handle which matches the A panel delivery is not correct.
