slantback37
Almost done with a 1937 Tudor Sedan. I need help installing the handbrake. I am using the under the dash handle. I have the cable that goes on the handle. At the other end of the cable is this elongated part. I have cables from the rear drums up to a plate that holds the cables. I also have another cable that has a threaded end, but also has that elongated part. Do I have the wrong cables? Thanks
