Jim M
Yesterday I wanted to check the toe in looked in the Les Andrews manual. The chalk on the tires looked like a very suspect way to get an accurate so my old carpenter instincts kicked in. I cut two 20 inch sticks, drilled a hole in the center and mounted the sticks on the hubs. Very easy to put a tape measure on the front and back. Found out the toe in was 5/16 which was contributing to shakes, etc. Loosened the tie rod clamps and within minutes was at the 1/16 they should be. Hope this helps someone. Jim
