Milton
Ok, this thead is to allow those of us who need to confess to being stupid a venue to do so.
In 1956 I was a young lad of slight build so slight that I could barely crank start my 1931 Ford. Furthermore, the car constantly suffered from a low battery. The first time I learned about not retarding the spark I had the motor rotated to the pull spot. I pulled, it pulled, I knew I lost the tug-of-war when my chin hit the radiator shell and I damn near bit the tip of my tongue off. Blood all over the damn radiator.
As I mentioned I was, at 70 lbs. soaking wet, crank start challenged. I had a routine to beat this. I would simply roll the engine up to a compression stroke, set the crank up past the top and nimbly step on the bumper and put my other foot on the crank. Can you see this coming? Well, another lesson on the power of an advanced engine. I stepped down, it kicked back, did a 180 and smacked the living hell out of my shin just below the knee.
So many times, back then, I would limp crawl or move however possible to get in the house so I could scream and moan. So I can sympathize with Great Lakes Greg posting about his tight engine giving him a blister.
Anybody else have a confession, its good for the soul.
