Hand brake brackets
Great Lakes Greg
The hand brake brackets do not appear to have any kind of bushing to ride on in relation the the cross shaft. The cross shaft I have is worn about two thousands into it from rubbing the past 90 years. I am not losing any sleep over it, but is there a fix of some sort, or does it not really matter?
No bushings - steel to steel contact but there is a corresponding hole in the frame rail with a small felt that is a lubrication point - .002 is negligible - .030 - .050 and you might be able to see that.
