Halibrand 101 Parts
JT1930
Does anyone have part numbers for all the bearings/parts needed to a halibrand 101 case.
I know hotrod works has the pinion shaft and lower shaft that fit. Are the 101 and 201 all the same bearing sizes ?
I believe winters v8 quick change are the same parts? If you check out the site it might be able to help further also very good assembly diagrams
For the mean time
Hotrod Works Lower Shaft # 1271
Hotrod Works Pinon Shaft #1270
Speedway Rear Cover #4152936102
Speedway Rear Cover Bearings #912b6304
Speedway Pinon Bearing #912B6307ZZ
Speedway Lower Shaft Bearing #9126206SZZ
Speedway Lower Shaft Bearing #912B6306
Speedway Front Seal #912S15522
Speedway Spacer Kit #912B6304
I believe should get you started
