Halibrand 101 model a quick change
Yucaipa
California
Price
$950.00
I have a Halibrand 101 Model A Quick Change Case I was piecing together. The case is a little rough and dirty. I had a machinist remove the broken bolts, sleeve it and make a repair on the case. Included is the old pinon bearings and spacer and about $650 to $700 worth of new part's. No ring and pinon or gears. PM for phone if you have any questions. Prefer local pick up. Might ship?List of parts.
Hotrod Works Lower Shaft # 1271
Hotrod Works Pinon Shaft #1270
Speedway Rear Cover #4152936102
Speedway Rear Cover Bearings #912b6304
Speedway Pinon Bearing #912B6307ZZ
Speedway Lower Shaft Bearing #9126206SZZ
Speedway Lower Shaft Bearing #912B6306
Speedway Front Seal #912S15522
Speedway Spacer Kit #912B6304 and a couple of misc bearings.
