pyrodork
i've got one of the cheaper-looking horns with a half-round rear end rather than the traditional can type.
this may actually be the same horn, but i haven't found any markings yet, so i'm not sure. everything looks exactly the same.
http://www.ebay.com/itm/SPARTON-MODEL-C-8-HORN-FOR-36-FORDS-OTHER-APPLICATIONS-6-VOLTS-/200674690646?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2eb924c656&vxp=mtr
i did try connecting it to a 6v battery and i got sound for a brief second before i disconnected it and i couldn't get it to sound again. cracked it open and it was pretty rusty. obviously a rewire is in order. i think my field coil is good, but the cylinder part (capacitor, coil, ???) came apart during the de-wiring. diaphragm looks useable, but the flat disc it's connected to has corroded over the years (still had a half inch of corrosion!) and is far from round now.
i've cleaned everything up to the best of my ability, but now i need to figure out what that cylinder was that broke and if i can find a repop disc. if repop field coils are available, i'd probably get them just for the sake of replacing all the electrical components.
also, if anyone has further information on these types of horns, that would be great. i think the screw that sets the points above the field coil is for volume, and it sounds like the screw that holds the cover on may be the tone adjustment? i think it's a pretty safe bet that it's not an ahooga horn, but i honestly have no idea.
thanks!
thanks!
