If there is always pressure being present in the exhaust port how is oil consumption a factor from the exhaust valve and guide? I understand the intake as you have a vacuum that can pull oil into the cylinder due to a bad seal and or guide. I’m not arguing with anyone’s opinion just trying to find out why exhaust valves have seals.
There may not always be pressure in the exhaust port. When the exhaust vale opens, a pulse of hot high pressure exhaust gas moves through the port into the manifold, followed naturally by a pulse of negative pressure. While all 8 cylinders combined will create positive back pressure in the downstream exhaust system, right at the port there will be constant cycling of positive then negative pressure.
