gypsycandle
Hi Guys, another update. I put the radiator back in today, I discovered that it is stamped "made in Canada" and on the back of the top tank is "AB underscore L" on a little raised boss.
I teased the timing a little more and the backfiring went away, It ran for about 10 minutes. I ran out of gas , put more in and ran for about another 10 mins noticing that the generator has no output, the exhaust manifold is leaking(maybe the gaskets out of place?). There is a healthy amount of blow by coming out of the oil filler tube.
Looks like i'm going to need the asbestos gasket on the tail pipe to manifold connection, i can hear the exhaust coming out.
Oh yeah and after 20 mins of running it overheated maybe because i was running it retarded for most of that time? At least i know the over flow tube is clear.
I backed it out of the tent twice and each time the throw out bearing was humming (needs grease or replacing). Clutch chatters a bit also.
I tried adjusting the throttle linkage to slow it down, n/g it was bent and the screw never reached the peg. I also tried adjusting the idle/air mixture jet with no difference in the running of the engine...lol..lol Only the GAV made a difference when i turned it all the way off...it stopped.
Question: 1. what can be put in the radiator to clean it out?
2. how can you test the out put of the generator with a volt meter?
I have a video of it running but will have to figure out how to get it on Youtube, i guess.
ok that's all i know for now, more later.
thanks,
Michael...
thanks,
Michael...
