Rocketsled
During the recent near 0F weather, the rear axle of the 1941 Toro General
I'm overhauling refused to move.
I removed the bottom bolt from the pumpkin housing and during a warm spell some goo oozed out, but only about 2 oz.
The stuff which drained into a stainless steel bedpan is the color of dark chocolate, and a lot like candy. I tried cleaning the pan in turn with lacquer thinner, acetone and denatured alcohol, but none of them had any effect on the gunge.
Has anyone successfully cleaned up someting like this, and if so, what solvent did you use? If nothing will, perhaps warming the pan is the only way out.
Its like someone but Permatex #1 in the axle housing.
Thank you.
Thank you.
