Ok, so I sanded the frame under the ground strap (for good contact) even installed a new bolt, added an additional ground as suggested above, printed out a Model A wiring diagram and rewired all the wires to the terminal box. As a test I just had the instrument panel outside the car on the tank, no speedometer cable yet. Started car everything great, no melting wires (I melted the amp wire previously) no sparks. Great…all fixed. Not!!! Installed instrument panel back inside everything reattached, ready to go, as soon as I attached the battery cable my wire from the starter to terminal box melted. I will be purchasing the grommet for the ignition cable as suggested. I don’t understand for as simple a wiring system this is why is it giving me such a hard time.
