wamnram
I had an interesting problem occur the other day. I was in my completely stock 36 with a stock six volt system and Optima battery. I had been running fine for a while and was sitting at idle and the engine died. When I pressed on the starter switch, it acted like the battery was completely dead. I pushed the horn button and nothing. turned lights on, nuthin. Flipped the ignition switch and no movement on the ammeter. I got some fellas to push me and it still would not start. After checking everything over for ten minutes and finding nothing unusual, got back in and pressed the horn button and it honked. Hit the starter switch and it fired right up! Drove around all day and no problems. So, after thinking about it for a while I thought it was a loose connection from battery to frame or battery to starter and fuse block, or open connection inside battery. But then again, why would it not run when we pushed it? It seems to me it should have run off the generator if you lost the battery while it was already running.? (checked Gen and it charges fine) Any ideas?
