Tom F OHIO
I have a 52 v8 and would like to add a ground wire. Where would the best place be to do this. Thanks....
Is 00 wire the same as 2.0 gauge wire?
Two major grounds are needed. One with a good size battery cable from the battery to a starter, since the starter takes the most current. The engine is mounted with rubber mounts so then another smaller cable is needed from the engine to the firewall, that ground carries the voltage for all of the lights and other stuff on the car. All cars have those two basic grounds. Each component has its own separate ground which then runs through the sheet metal back to the firewall cable to the engine block and then back to the battery.
