Mike
No, if you install the clutch backwards, you will not be able to shift into any gears.
I recently spoke to the guy who owns the car, he changed the entire transmission & bell housing and it still had the same problem. We then found that the only thing left was the clutch pedal, so we removed it and IT WAS DIFFERENT SHAPE THEN THE ONE I HAD IN STOCK. We are not sure what the pedal is off of maybe AA?? after we swapped the clutch pedal everything was fine.
mike
mike
