radioFlyer55
I have an 8BA that I am rebuilding, and I wondered about the practicality of grinding the valve seats myself. I see that used seat grinders go for a couple hundred bucks on ebay, and the quotes for a valve job I have so far are in the $350 - $700 range. How hard is this to do myself, assuming new valves?
The info I have so far indicates that the intake & exhaust valve setups are identical, the only real difference is the use of a rubber o-ring on the intake guides. The valves are ground at 45 degrees, and the seats seam to get a 3 angle grind. SO:
1) Do new valves need a grind, or are they usually all set to go?
2) I am guessing I can measure the valve height with a dial indicator, and so get all the valves to sit at the same depth.
3) I do have 2 pitted seats (intakes), can these be ground out, or are new seats indicated?
4) what about these 1.6 chevy valves I hear about? how much more trouble are they to install?
5) I have what appear to be Isky lifters, can they be reused with a newer cam? They seem to have some wear visible.
6) I am not sure what the cam I have is, it has 0.335 lift for both intake & exhaust, I am pondering how to attach a degree wheel to the cam itself to learn a bit more. Is it practical to regrind a stock (or other) cam for a moderate performance improvement?
