I am getting ready to paint my new block, pan, and heads. All parts are bare clean metal. I will apply metal prep prior to painting (phosphoric acid). My question is: Should I use primer when using Hi temp green spray enamel (like what Mac's sells)?
Rick,
I've had fairly good results with MAC's spray can green engine paint. I
learned early on to spray an even coat of Rustolem gray primer on the parts
prior to the green. Doing this reduces the number of coats required and gives
depth.
OMHO
Charlie ny
Thanks. The can does not say anything about priming.
WOW I did not know the pan is to be painted black. THANKS
What other brand of paint is better than the spray can stuff from Mac's? I have had good luck with it on the intake manifold when followed "VHT" by high temp clear coat.
Bill Hirsch paint is the very best there is. It can be sprayed or brushed on clean bare metal. Flows out nice and smooth and is durable and very long lasting. Very resistant to gasolene too. Has a long shelf life. I think it's about $35 a quart. A quart is more than enough to paint an engine.
Imho. I suspect that the paint on the engine was for show room appearance only. Nobody at Ford expected it to survive for very long. Doing anything more than blowing alkyd enamel on a clean metal surface is more than what was done at the factory.
