wondering if someone with the Ford "GREEN BIBLE" could tell me if there is a listing for interior door latches for '40 woodie . I need passenger side front and rear latches....thanks in advance
The so-called "green bible" is a chassis parts catalog and does not include body parts such as door latches. Hopefully someone with the appropriate body parts catalog will respond.
39 - 40 Ford Mercury Body Parts. List.
RH Front Door Lock 01A 7921812
RH Rear Door Lock. 01A 7926412
I hope this helps I do not see the word “ latches” in the door parts list numbers.
Since the 40 part number is 01A prefix, something is different then the 39 part or it would have a 91A part number. It is for sure different then the 41 so 40 only. I have a restored 40 wagon and may have something. I will PM you if I do.
