Great advise on bad condenser.
ba49
Again thanks to the great advise found on here you saved me alot of work and time. there was a thread about modern points and condensers about 2 weeks ago and it was mentioned several times that condenser failure can mimic carb problems. Anyway I was warming up my 30 coupe to test my newly rebuilt wiper motor from Bert's and it was running really well considering sitting for the winter. All of a sudden it started acting like it was running out of gas. I thought it was a plugged fuel line so I blew air back through it, everything was open. The carb was a new Zeinith so I changed it out with a spare and it did the same thing. I then tried plugging the vacuum line in case of a leak in the new wiper motor, no difference. Then I read the thread about the new style condensers which I had changed to last fall. It had maybe 100mi. on it. So I bought a heavy duty Acell one and put it in. Problem Solved! If I wouldn't have seen that thread I would never have believed a bad condenser would have caused those symptoms. I think I will convert back to original points and condenser. Anyway THANKS GUYS, you are the greatest.
Bill
No, the car is the greatest. We're all just lucky to be associated with it for a short time.
Joe K
