If you have an original owners manual, you will find a "lubrication and maintenance chart" in the center of the manual. Any part marked with an "A" indicates that it should be greased with pressure gun lubricant. All other points to be oiled or greased are depicted on this chart. Ford recommends this maintenance to be done each Fall and Spring.Btw is there drawings showing all fittings to be greased. I checked owner manual and vanpelts site without finding.
Found it thank you!
Kube, any input as to why there is an advantage?
Actually one should always take the weight off of the spindle pins when greasing. That isn't backyard mechanic advice but rather professional (schooled) advice.
Never too old to learn something!
No, it really shouldn't make any difference. Have you been able to grease them in the past?
