Don't use the white lithium grease on bearings, it's good for cables, hoses and rub points, but not bearings.
Steering column, even if there is a grease fitting there.Is there any place it should NOT be used?
To clarify my original post. I am using the red wheel bearing grease for the bearings. Is it all right to use in other places - shackles, king pins, steering arms etc.
Yes. The only "special" grease I use is for the water pump. Wheel bearing grease for most general purpose stuff.To clarify my original post. I am using the red wheel bearing grease for the bearings. Is it all right to use in other places - shackles, king pins, steering arms etc.
