cuzncletus
I have a 46 59a motor, not sure which fan. It's a 4 blade with the wide pulley, all lines up so that should be OK. There's a slight wobble in the fan when the belt isn't tight but I've run things looser. My question is grease. There's a small screw in the hub that is apparently for lubrication. Is this drip lubed with a fine oil (3 in 1 type) or can a nipple be screwed in so it can be greased?
