sconnors
I have these two grease guns (see photos) and these are the fittings on my ‘30 Deluxe Coupe (see photos). Can I use either gun on this type of fitting? Thanks in advance for any input.
to make it easier. you can buy the end coupler that fits the style of fittings you have and then switch them back and forth on your regular grease gun. the coupler end on your big grease gun won't work on those nipples.
The small silver grease gun is designed to work with the original cone shaped grease fittings. You should try it first.
Snyder's normally sells the adapter to put on the end of you modern grease gun hose, but they are out of stock right now. This adapter sort of seals against the original cove shaped grease fittings. A lot of grease leaks out the sides.
A-353032 is their part number.
Thank you! So,the fittings I have are the original type?
As Jim said, those fittings are the original style ones that require the original style grease gun. IMO, if the grease fitting is even a bit clogged, the modern gun even with the adapter won't do the job well but the slver one will. In fact, I prefer the original style fitting and gun.
On the other hand, The modern style fittings are available in "tap in" form. Just remove the old fitting and tap the new one in. Then, ypur modern gun will work.
Curious to know how they greased these "back in the day" since all the videos I watch seem to say you need a grease gun with a hose to "get into the tight places" I mean these guns were made for the Model A so I would think you should be able to access ALL the grease fittings on them with the original style gun. Or did they have some type of extension hose even back then?
You can get to all of the grease fittings with the original gun. You push the tip hard against the grease fitting and then depress the plunger. You have to pack the grease into the barrel, which is kind of messy, but after you do it a few times, it's not too bad.
You can replace most of the grease fittings with new "modern style" fittings, if you want (some are really hard to get to), and then use a modern gun on them. As mentioned above, that is often the only way to get grease into a bushing after the old grease has dried up and hardened in there. You need the pressure to push the old grease out and the new grease in. But once you have done that, the more often you grease, the easier it is for the grease to go in the next time.
Many people like to leave the original-style cone-shaped grease fittings on their car, instead of installing the modern ones, because they "look correct" and they "look old, like the car". Once you have all of the fittings taking grease for you, this is not a problem, the original gun will work. It's cars that have sat for a long time without driving that are hard to get grease to go into some fittings. I have disassembled a few places just to clean the hard grease out, put it back together, and then the grease went in easily with the original style fittings and gun.
I have Snyder's adapter for original fittings (the one that is out of stock right now) on a modern grease gun and, to be honest, I'm not impressed. It leaks around the sides too much. Someone needs to design one that seals better. Part of the problem is that a modern gun will generate a LOT of pressure (which you need on some fittings to get the grease in) and the adapter just can't handle that pressure, so the grease squirts out the side. If you don't get fresh grease in, you don't soften it up to make it easier to take more later, so it continues to leak out the side.
And does the coupler have specific name or part number?
I use a needle fitting tip on the old push types. Needle type fittings are used on the helicopters in places where they don't want any protrusion sticking up plus they reduce weight. The hole size is pretty much the same. This link illustrates what I'm referring to. They are available from many sources. Some plug on with a zerk fitting in a socket and some screw on. I use the screw on and a flexible hose type gun.
https://www.lowes.com/pd/CARBYNE-Gr...FWAdFvXdOWAzrXSQeJnseS4JUcZCLvVK2-pUGZg7dMCiI
So this would appear to solve the issue of having to use two guns? Because you could grease both types of fittings with this?
Never packed the original style guns is there a trick to it, or just shove the grease down inside with a stick?![]()
