Grease Gun Adapter
John Gibson
Who makes an adapter that is 1/4 x 28 female thread on one end and the other end is for a 1933 grease fitting that is a conical head with just has a small hole in it for grease to flow through? I could change all the fittings to modern Zerk style but really don’t want to go that route.
TIA,
John
It’s understandable and very laudable that you want to keep your car original, but as the old fittings are so unworkable, consider using a modern zerk as a convenient tool, then replace with the original again.
Ordered a couple of them from the Model A peddlers. I’ll remove all the grease fittings, give them all a really good cleaning and see how it goes. Thanks for your advice. John
I thought that by 33 Ford had changed over to the more modern style of Zerk If the fitting is on one of the tie rod ends I would change it out since the body of the tie rod end is a carry over from late model A.
