If using original type transmitter bearings that are not sealed, regular grease is fine and will end up being mixed with the transmitter oil leaking thru the rear bearing.
If the bearing has been replaced with a sealed unit then a loose grease or a mixed 'slop' [ technical term] can be made and used.
