If she's the same Molly I once knew, she personally bent many a shaft in her time.
Molly Cules...she worked at the cafeteria next to the crankshaft foundry at the Rouge plant. Was said to have inspired the workers to make sure their crankshafts were always straight, even if they were laid flat.
True, if you store it balanced on edge it may fall over and break something.I feel better storing a crank laying on the floor, if I store anything standing up I'll knock it over before I get around to using it.
I have always been amazed at discussions like this. Here's a crankshaft that can take the firing impulses running in an engine for 90-100K miles, and some prople wwill think it will bend sitting on a floor? Give me a break!
Cast iron cranks will definitely sag if stored horizontally and not supported correctly! The longer and heavier they are the more apt they are to sag. If you don't believe it you just haven't experienced it yet.
A Model A crank which is shorter, lighter and made of steel is not so apt to sag if stored horizontally.
Bill
And you base this assertion on what empirical evidence?
It pales by experience. If you know for a fact, based upon 63 years of building engines, that storage of a flathead Ford V8 crank in a horizontal position results in a bent shaft, I guess that ends the debate. Still, your certainty on the point does beg the issue of how long a Ford flathead V8 crank must lay in a horizontal position before it is ruined by gravity. Are we talking months, or years?
I have machined Flathead cranks from all walks of life and found absolutely no difference related to storage conditions. Frankly, the cast iron crank might be LESS likely to "sag" than the steel crank. If gravity damages a crank in the horizontal position just imagine how badly damaged it will be when stored on end!! If you have ever straightened the crank from a wrecked engine in a crank press you will see how far it must be moved to overcome "spring-back".
