Ajracing9
Hi guys, looking for some advice. I have the Granada disc brake conversion. Close to 5000 miles ago I installed a new a booster, master cylinder, disc brakes on front, new rear wheel cylinders, all new brake lines with SS braided at all the flex lines. Nothing is pinched. I have no leaks. Pretty much since I installed them the front wheels lock up. For instance when I put in neutral and roll it will stop like in stepping lightly on he brake. Usually only when hot. After a while they free up. I bled the system 2 separate times with brand new fluid each time. I lubed the slides. I've remove the master from the booster to see if the rod was pressing but even detached in changes nothing. Any ideas? Thanks for reading
