GPS on 6VDC?
Ken B
Does anyone know of what make and model GPS will work on 6VDC?
The one I have won't and I would like to get one for our Model A.
Thanks
I use a "TomTom"
It was the first TomTom ever to be available
The one prior to TomTom-One :eek:
20 years old !
Still going strong
(bought with Data-level 18 and actually updated to data-level 981)
Runs great on 6 volt, but doesnt fill its battery.
To find tiny roads while going distance over here, i use a "Tripy2"
I guess this aint availlable in US.
Tripy2 was made for dessert-rallies on motorbikes and goes
14 hours on own batteries
I even manage to fill the battery of my smartphone in the A.
As so, any Smart-Navigation should work there
(but i never tried).
Have fun Christoph
BTW
Might be interesting to know, which one you tried without success.
I have an older Garmin Nuvi model. I tried wiring it directly to the battery (polarity correct )and it won't charge the unit.
Try the Ulysse Speedometer app. Uses GPS on your smartphone. Accurate and easy. Runs for hours on your normal phone battery.
But for really long tours, I built a little cigarette lighter adapter with a 7.2V R/C battery. Use that for 12 hours, then recharge in hotel room.
This strategy keeps all the ugly wires out of your Model A.
https://play.google.com/store/apps/details?id=com.binarytoys.speedometer
My paper map works great as a liner for the 6 volt battery box and my compass helps find the polarity of the magnets in the magneto on my model T
Paper and a compass work great but my eyes don't much anymore. Besides, it is nice to program them for a nice "sexy" voice giving you directions for a change.
It's not about the destination....it's about the journey..
I carry a GPS but I find that I usually just drive GD (General Direction) and then refer to a folding map if I have to find a specific location. If I am going somewhere specific... since it is an old car.. I do it the old way. I look at the maps before I go.
I'm a gadget freak but I have been finding I have been getting away from engineering myself from point to point to actually looking at a map and enjoying the ride.
That said... most modern GPS use a USB for external power and that is 5 volts. Most will tolerate 6 volts but that choice is at your own risk. I built a small 5 volt regulator that feeds the phone and GPS.
I have asked this question in the past but did not get a solution.
Is there any GPS or can it be done on Google maps to PRE select the route which I would like to take? I do have a iPad.
Thanks for any comments.
You can easily plan a route in advance with Google Maps. It will give you it's first pass at the quickest or shortest route, but then you can drag the line to follow the roads you want to take.
You can export that custom route to SOME GPS makes and models, not all. So do your homework on that feature before you buy a GPS, if that's what you'd like to do. I learned after I bought my Garmin Nuvi 1350 that it does not have this feature. When I replace it I will get a model that does. It's also a bit of work to transfer the route to the GPS.
If you want to use Google Maps on your iPad as your GPS, I don't see why you can't modify the route and then start following it. but I don't have an iPad so I have never done it myself. You'd have to experiment.
I have a Garmin Nuvi 2555 LMT and it all works fine on 6-volts. I mounted a plugin on the floor board just behind the transmission with wires with clips on each end so if I want to remove the floor I can detach them. Interesting, the speedometer matches the speed to a "T".:D
