GPS driven speedometer
Boeing
I am looking for an instrument cluster with a GPS driven speedometer for my 1946 Ford pickup. I am having some difficulty locating the proper speedometer driven gear and I am having trouble with the speedometer itself. If someone has some information on a GPS driven cluster system that looks original I would appreciate it Thank you.
Check out speedoservice.com
I just saw something on the HAMB from them. They have a GPS unit that is used on mechanical speedometers.
It's not cheap, but a better alternative to buying an aftermarket speedo.
Speedhut.com also has a GPS unit that works with stock cable driven speedos.
Speedoservice unit is called Classic Speed
Speedhut unit is called Speedbox
Speedhut also has GPS Speedometers that don't need separate boxes.
