chesapeake bill
Oil leak on Fly wheel ( on FW cover, not in housing) OK, pan drop completed, cleaned thick black sludge out of pan, all new gaskets installed (although the back cork-like gasket might have been cut 1/16 short it was hard to tell.. (so I put gasket sealer on edges as I thought that the cork would compress some as the pan was tightened) .. Now the leak is worst. What next? No oil in Fly Wheel cover but seems to be only on front of the cover. Could there be another seal up higher on the Flywheel that’s dripping down? Did I just screw up on the rear gasket? Do I need to drop it again #%&##! if so do I need to replace all the gaskets again? Advise please!
