Marleysurf
So I finally received my order from Macs today. Nothing crazy but I got water pump packing to hopefully fix my leaky water pump! Some interior handles, and what I most excited about is all the pets to fix/hook up my choke rod etc. Since I got the car 2 weeks ago I haven't been able to adjust the choke. The biggest issue with he car is that it smokes pretty bad, while on or driving. Just out of the exhaust. I'm hoping that being able to adjust the choke will fix it, or at least make it better. My friends and wife's dad tend to think that is the problem, so we will see.... If that doesn't fix it I guess I'll be attempting to change the seals. I need to pull the head anyways as the gasket leaks a tiny bit...
Any advice in choke or should I just follow the basic how to's like when it was new. Everything is stock so technically the choke should be able to be used like it was originally used! Thank and I'll update when I see if the problem is fixed!
Also any tips on putting the new packing in the water pump! I've never done it but I figure it should be really straight forward and pretty easy. I have the "red book" by les Andrews, so I'll read that and proceed on step by step.
