Old Redneck
I had my 33 in the big garage behind the house and have not had it running for a couple of years.I did keep the battery charge so that was ok. But when I tried to start it gas was running out of the fuel pressure regulator that was in the gas line. So I put the original gas line back on.Still the car would not start. The electric fuel pump wasn't working either. I poured some gas in the carb and it started but shut down right away. Maybe fuel pump? I desided to pull the 33 over in the garage at the house and go over it complety. I drain all the gas out of the fuel tank and boy did it stink. I had a new 6 volt electric fuel pump so I put it on the car.I got 5 gallon of fresh gas and then tried to start the car. I turn on the electric fuel pump to get the gas up to the carb. Still won't start. Again I poured some gas in the carb and the car started for a short time and now I change the carb. Then I primed with the electric fuel pump then hit the starter and she started right up. The carb was the problem all the time.The 33 had a 97 on it and always ran super until now. Barb and I went for a little ride to check it out and she runs very nice. Sitting does any car no good. She a bit dusty and I need to drive her more then I do.
