32Gnu
Need help running a gas line from the tank to the pump on my 3 window.. the tank is an aftermarket plastic job.. is the drain plug also the feed? is there any specifics you could give me concerning the routing/size/type of line? I am using an 8ba engine and the fuel pump inlet is pointing towards the drivers side.. Thanks
