Gonna drive every day
Gino
Hi, I live in the north east. Is there a good or preferred way to have heat in the cab of my pickup? I'm thinking about a 12 volt battery in a box in the bed and a ceramic heater? Appreciate the help Gino
I'd suggest you find an Otwell Health Heater, which replaces the exhaust manifold. I'm very pleased with mine, especially since I live up near Lake Superior!
If it will fit in the cab, a Southwind Heater will do the job. But I don't know if it will fit.
Get an old Autolite manifold heater and do the install. You may already have "the hole" cut thru your firewall. Many do.
I have used a small coleman catalytic heater and it will definitely keep you warm and with the volume of air leaks in the A, no O2 concerns.
Resistance heat from a 12 volt battery will drain the battery very quickly, so it isn't really practical.
Do you happen to have a photo of that "hole". I have a hole in the firewall of my '28 roadster and have always wondered what it was for. I looks factory and has always baffled me.
PeteCruz, I don't have a photo yet of my manifold heater door hole, but it is a very LARGE one in the firewall, just above and in-line with your exhaust manifold. About 2-1/4" diam. Up here in the Northeast, I can count on one hand, how many A's I've seen that DON'T have that heater door hole. That's restored ones, "woods finds" and everything car in between. I like the idea of a water heater, but the "A" has such limited room up front for the heater core and a real pain to remove the floorboards sometimes if all the floor screws are in place.
Here's one off Google
Ok, I like the idea of a hot water heater. If anyone can give me some info on the brand of heater and how to do it I'd be grateful, thanks Gino
My vote is water heater. If you choose the exhaust manifold heater you'll smell like the engine compartment. Hot water heaters aren't hard to install. Just a little piping and mounting the box inside.
If I install a heater it will be a water heater. I will go to the junk yard and find one to use, then make my own sheetmetal box for it. I will duct the heat to a floor grate. This way I won't loose any interior space.
I've also been thinking about just wrapping the muffler and using that heat through a floor grate. That would be even easier as I won't have to run hoses and change the water fittings.:)
